04-12-2025
19:11
15:20
04-12-2025
19:11
15:20
My 1-year old Inspire 3 has box with line through it on the top of the display
I have rebooted the device several times
04-14-2025 18:54
04-14-2025 18:54
Hi Annazon53!
I had the same problem with the box-with-the-line. It indicates that your Inspire 3 is not connected to your phone. If you don't care about it not being connected to your phone, that's fine. But if it's simply getting in the way, there is a way to remove it. On you Inspire 3, if you scroll up to settings and go to display settings, there is a setting called status tray you can turn off and it should go away. I hope this helps!
04-12-2025 21:00 - edited 04-12-2025 21:05
That is one of the new screen notification icons that were introduced with the 214.24 firmware update.
I believe that notification icon indicates that your Fitbit is not connected to your phone, but there are several reports that are indicating that these new 414.24 screen icons aren't working properly.
04-12-2025 21:10
04-12-2025 21:10
My battery is fully charged. This has been going on since the update. The DND is off and I factory reset it to try to clear the slash/box (with no success). It does not prevent my using the tracker, but it is annoying. Strangely, since the time rolled over to April 13th, I have not seen the slash/box. Maybe I will wake up with things magically sorted.
04-14-2025 18:54
04-14-2025 18:54
Hi Annazon53!
04-21-2025 06:52
04-21-2025 06:52
Thank you soooo much for this information. It stopped mine. 👍🏻
