08-21-2024 23:47
08-21-2024 23:47
After recent update inspire 3 is showing incorrect heart rate and zone minutes
08-22-2024 03:03
08-22-2024 03:03
Confirm that after latest update inspire 3 shows incorrect heart rate and zone minutes
08-22-2024 05:33
08-22-2024 05:33
I have the same problem, after the last firmware update, there are false spikes in the heart rate measurements for no reason. This reduces the Inspire 3 to a very expensive step counter, all other measurements are totally false and useless. I want to downgrade back to the previous firmware.
08-22-2024 08:17
08-22-2024 08:17
Hi RG63
This is happening to me. EVERYTHING do not seems to be functioning correctly sine the latest FW update. From heart rate to zone minutes; it's going "crazy" all of a rush. Let's hope there will be an update to fix the bugs.
08-22-2024 08:29
08-22-2024 08:29
Has anyone actually had a positive customer experience after downloading this new device FW?
I recently received the red dot letting me know that the new FW was available for download, but that doesn't sound advisable to me at this point in time.
08-22-2024 11:44
08-22-2024 11:44
Exactly. I'm moving around and it doesn't update heart rate or zone minutes. There was one instance where the device only recorded 9 minutes in one day. And I walked over 16K steps. How does that happen????
Best Answer08-22-2024 13:14
08-22-2024 13:14
Incredibly bad FW/SW QA test of new FW/SW releases.
08-22-2024 13:56
08-22-2024 13:56
I seriously just bought this thing yesterday and updated it and now it's not showing the correct zone minutes or counting my fat burn zone
Best Answer08-22-2024 15:40
08-22-2024 15:40
Same for me. I did the update about two weeks ago and my stats have plummeted compared to what they consistently were for the past year-plus. Nothing else has changed in my routine that would cause this problem. I’ve tracked my heartbeat with other tracking apps during this time and they are consistent with earlier results.
08-23-2024 08:35
08-23-2024 08:35
Same happens to me - under reading by 30 bpm! Completely useless. Hopefully someone will notice at Google!
08-23-2024 09:28
08-23-2024 09:28
don't do it if you can avoid it...
Best Answer08-23-2024 11:47
08-23-2024 11:47
Since the latest update, my higher heart rate readings are inflated by 30 to 40% (although lower rates are more accurate) and sometimes show implausibly rapid variability. Also, today Fitbit failed to note the end of an elliptical session, counting an extra 15 min of sitting and other movements.
Are you listening, Fitbit engineers?
Best Answer08-23-2024 11:52
08-23-2024 11:52
I was getting erratic heart rate readings prior to the update. I walk at a pretty steady pace over basically flat, paved surfaces. During the course of a 30 minute walk, I'll see my heart rate climb to about 130 initially but 2 or 3 times it will fall into the 70s even though I have not stopped. I did see this on the prior firmware version but it does seem to happen more often lately. I attribute part of the problem to the Fitbit losing contact and/or moving around on my wrist. It it worse when I walk than when I run which I can't figure out.
Best Answer08-23-2024 13:01
08-23-2024 13:01
Best Answer09-08-2024 18:53
09-08-2024 18:53
Since the update my Fitbit reports heart rate so slow I’m probably dead. FixIt please Google!
09-08-2024 22:47
09-08-2024 22:47
I managed to get a warranty replacement. A reconditioned unit that has the old software. Back to my expected rate. What it looked like the new software did was smooth the HR.
Best Answer09-09-2024 05:07
09-09-2024 05:07
Please update anyone had any SW fix available
Best Answer09-09-2024 08:01
09-09-2024 08:01
Since the update I'm barely registering any zone minutes. Before hand I got them every day. I've done a 5.5 mile walk today and a workout and got 1 zone point. Normally I would have gone way beyond my 22 goal per day.
09-09-2024 12:20
09-11-2024 01:30
09-11-2024 01:30
Prior to the FW update my heart rate during the walk exercise was reasonable and steady. After the FW update my heart rate is now highly erratic. I have not changed things on my end other than the FW update. Thank you Google ML!
