11-29-2023 14:02
11-29-2023 14:02
I just bought an Inspire 3. I CAN FIND NO MENTION of how it sends alerts! Nothing. I assume it vibrates like my Flex 2, but if it does, I can’t feel it.
Does it also beep? Is the vibration intensity variable? Or does it only show up on the display face?
it’s amazing that even a search of this feature returns nothing.
Can anyone help? Can anyone send me to instructions that I missed?
Thank you
Best Answer11-29-2023 14:15
11-29-2023 14:15
Hi @JimmyNYC alert article - click to read. notifications article - click to read.
You can change the strength of the vibrations you get on the Inspire 3. See Page 23 of the user manual.
11-30-2023 09:23
11-30-2023 09:23
Wow. I missed that. Thank you. I’ve adjusted it to “strong”. Hopefully I’ll be able to feel it now.
11-30-2023 10:04
11-30-2023 10:04
@JimmyNYCmine is on normal, but if I'm busy doing something, I can miss it. Keep an eye on your battery though, I'm thinking that the stronger the vibration, the more power it takes from the battery.
