11-28-2025
09:55
10:02
11-28-2025
09:55
10:02
My inspire has registered 100% after one day, I'm worried the battery is dying.
Best Answer11-28-2025 20:35
11-28-2025 20:35
Welcome to the forums @tiger72 .
Thank you for letting me know the issue that you are experiencing with your device.
Please, make sure to follow the steps listed in this help article: Why isn't my Fitbit device's battery charging?
Best Answer12-01-2025 11:03
12-01-2025 11:03
Hi, @tiger72 , do you mean that it has *not* come to 100% after one day?
If that is the case, I would not worry too much. I would just remove the Fitbit from the charger and wear it as usual.
Moving forward, when your Fitbit is a little older (often once you have had it a year, and usually as it gets older than a year) you may find it needs more frequent charging. As I am sure you are aware, all rechargeable batteries have a limited life span, and as the battery on the Inspire series is quite small (it’s a trade off between a more delicate device and longevity…)
Do not worry about charging little and often - battery research suggests that this is actually optimal. Ideally for longest life you should avoid deep discharges.
So if you can find a routine in which you can pop your Inspire 3 on the charger for 15 or more minutes each day - perhaps when you are showering and getting ready for work or in the evening when you are relaxing with a book or watching television - you will find that that will keep the battery going as long as possible.
I hope this helps!
12-01-2025 13:24
12-01-2025 13:24
