02-22-2023
08:27
06:36
02-22-2023
08:27
06:36
Although I have my Inspire 3 set to automatically track several activities it often doesn't register them. If I have a walk it is often just indicated as Zone Minutes and isn't included in my week's activity record. It has occasionally recorded the elliptical trainer but not during the last few weeks. These gaps and inconsistencies are frustrating.
Should I request a replacement?
Best Answer02-23-2023 03:41
02-23-2023 03:41
Hi, @Sedgym, welcome to the community, auto recognize features can be reviewed & adjusted by doing the following. From the "Today" screen in your Fitbit app touch your icon in the top left corner>activity & wellness>Exercise>walk> here you can adjust the "Walks Longer Than" value, ensure the slider in the top right is in the on position & SAVE. Note with Auto-Recognize GPS is not engaged, If you want GPS & a map you'll need to start your walk in the regular way in your Inspire 3. If you find you have activities incorrectly labelled you can edit them (I frequently find gardening recorded as a walk) How do I add, edit, or delete Fitbit data and activities? explains the process. In my case I touch the "Exercise" tile in the "Today" screen of the Fitbit app>select the wrongly labelled exercise>edit pencil>type the correct label name>select from the drop down>Log It.
I hope this helps.
Cheers
Gr4ndp4 | UK
Best Answer02-23-2023 13:41
02-23-2023 13:41
