04-26-2023
07:24
11:21
04-26-2023
07:24
11:21
Hi there,
I can’t find my previous topic on the exact same issue, I probably never « Post »-ed it... Appologies if it’s a dupplicate.
I bought the Inspire 3 in order to track ma sleep, and only my sleep. I don’t need it as an activity tracker, yet.
However, it is (or fitbit android application) really bad at analysing my sleep data. It shows me that I am in a light or ever paradoxal sleep, while I am currently well awake. I have got poor sleep, starting from 2AM and wanted to monitor the awake time.
My heart rate is around 53bpm as idle on the day, which is not too far from the value while asleep, might be the issue here? Is it something known?
Thanks,
Best Answer04-28-2023 11:25 - edited 09-14-2023 11:16
Hi there, @shaiton. Welcome to the FItbit Community Forums. Thanks for the details provided in your post about the issue with your Inspire 3.
As a first approached, I'd recommend to sync your Inspire 3 to the app after waking up. This will help to make sure that all your data is sync properly.
Also, note that your time asleep is calculated by subtracting your time spent awake and restless from your overall tracked sleep time. For example, if you slept 8 hours but woke up 2 times for 15 minutes each, your time asleep would be 7 hr 30 min.
Additionally, keep in mind when your body is completely at rest and you haven’t moved for about an hour, your Fitbit device records that you’re asleep. For more information, see How do I track my sleep with my Fitbit device?
To learn more about your time asleep in sleep stages, see What should I know about Fitbit sleep stages?
Best Answer05-01-2023 23:22
05-01-2023 23:22
Hi, thank you for your time, however I didn’t ask about the sleep time, only about the sleep stages which are really wrong on the sleep graph.
I clearly recall being awake from 3AM till 3:45AM for example, and it displays few minutes awake and then going to a light sleep or even a REM sleep, which is unfortunatly not right...
Which means my device is really useless and lying
Best Answer05-02-2023 05:05 - edited 01-31-2024 07:27
@shaiton Thanks for getting back and for those details.
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
