02-24-2023 08:26
02-24-2023 08:26
My fairly new Inspire 3 is used for sleep tracking only and had been working ok. Last night it showed sleep stages but no score and no spO2. I updated the app and it is now showing an spO2 for last night but still no score. Maybe it will work tonight. Also I will clean it more often, that seemed to be an issue with my previous Charge. Ideas?
Best Answer02-25-2023 05:33
02-25-2023 05:33
My brand new Inspire 3 is not recording anything relating to sleep at all, although everything else seems to be working alright.
Best Answer02-25-2023 08:42 - edited 02-25-2023 08:43
I've had mine for only a week but it's recorded my sleep every night. I thought it didn't give a score until it had recorded 14 sleep sessions. I'd like to know how it determines if you're restless. I assume that's based on movement like if you turn over or change position.
Best Answer02-25-2023 12:38
02-25-2023 12:38
Yes, I'm sure there's an algorithm that uses the movement sensor. I don't get this any longer because I did not start paying for Premium after the free trial expired. The Fitbit does a good job of tracking sleep, including the score, without subscribing to Premium.
Best Answer02-25-2023 12:44
02-25-2023 12:44
My Inspire 3 is now showing the sleep score. I updated the app and cleaned the sensors. With my old Charge 4, I got superstitious about cleaning it regularly. I think maybe the spO2 sensor needed cleaning. Either that or something on the Fitbit server end.
Best Answer02-25-2023 12:50
02-25-2023 12:50
Make sure the sleep tile is showing on the Today page of the app. Do not tell it you are going to sleep, it will figure it out.
Best Answer02-25-2023 14:42
02-25-2023 14:42
I assume the sensors are on the back of the tracker that contact your wrist. Mine is only a week old but it would never have occurred to me that they would eventually need cleaning. Learn something new every day!
