03-03-2025
03:55
03:55
03-03-2025
03:55
03:55
Hi
My fitbit inspire 3 is not registering calls or text. There are no controls showing o Bluetooth it says I need an app which I have.
I followed your advice on other posts. I have turned off Bluetooth unconnected all devices, I've logged in and out, I've deleted app re installed app, updated app and phone but the problem still happening.
My fitbit is 6 months old, this shouldn't be happening.
Do you have any other advice?
Hi there, @Maxthom. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Inspire 3 is still not receiving notifications. I understand your concern, I will do my best to help you with this!
As per the message on the Fitbit device's screen, it seems that your Inspire 3 is asking to be paired. With that said, I'd suggest following the steps below:
If you can't get started with your Inspire 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
