03-01-2025
05:34
17:35
ManuFitbit
03-01-2025
05:34
17:35
ManuFitbit
Hi,
I have an inspire 3 which was working fine until I noticed that today and yesterday it didn’t record a sleep score, heart rate or daily readiness. Everything apart from steps which seem to be accurate. Is there something I need to do to remedy this?
Moderator edit: clarified subject.
03-01-2025 17:32
03-01-2025 17:32
It's good to see you participating in the community for the first time @Elaine14.
Thank you for sharing the details regarding this difficulty with your Inspire 3.
Please troubleshoot the heart rate feature following these steps:
Keep in mind that you must see sleep stages in order to see a sleep score. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
If you see sleep stages but don’t see a sleep score, please note that it may take a few minutes for your sleep score to appear. In addition, for better results please try to let the device detect that you're awake or asleep by itself rather than doing it manually and make sure to keep the Fitbit app and the devices' firmware updated to the latest version available.
Best Answer03-02-2025 07:17
03-02-2025 07:17
03-05-2025 16:10
03-05-2025 16:10
Hi @Elaine14 ,
If you are seeing data on your device, but nothing on your phone, then it sounds like you have a possible sync issue. There are several recommendations for things to try to resolve the sync issue, but contacting Customer Service and working with them in real-time would probably be the fastest way to get your sync issue resolved.
Just click on the icon in the upper right-hand corner of the App Today screen and then navigate to Help > Help Center to contact someone on the Customer Service team who should be able to help you resolve that sync issue fairly quickly.
