11-08-2022 17:09
11-08-2022 17:09
Brand new Inspire 3 will not sync to my laptop, person in the fitbit chat said it's an issue right now, when will there be a fix for this?
11-09-2022
05:02
12:18
11-09-2022
05:02
12:18
@doglady321 Android 8 is the minimum Android OS for your Fitbit, so you should be fine. Fitbit Supported Devices Please be aware that you can't have both devices on your account at the same time. There is a programming limitation. The app will remove the Inspire to add the Inspire 3.
The Fitbit app for Windows 10 was deactivated in October. I'm confident that your Inspire was syncing with your phone since then. The Fitbit app for Windows 10 hadn't been updated since 2019. All of Fitbit's newest features are only on the mobile app.
Laurie | Maryland
11-08-2022 22:37
11-08-2022 22:37
I believe that all FitBits now will only sync to a smartphone and will no longer sync to a laptop. So I don't think there will be a fix for them to sync to a computer.
11-09-2022 04:33
11-09-2022 04:33
11-09-2022
05:02
12:18
11-09-2022
05:02
12:18
Laurie | Maryland
11-09-2022 05:07
11-09-2022 05:07
