02-22-2023
06:24
05:45
02-22-2023
06:24
05:45
My Fitbit Inspire 3 has gone crazy, it's showing that my heart rate is 170 even though I'm sitting still and I have manually measured my pulse and it's about 60...
The app states that I have burnt almost 4 000 kcal today and 385 zone minutes, but I have been sitting at my desk almost all day.
What to do?
Best AnswerHi, @Zirqon, welcome to the community, I suggest you restart your Inspire 3 as demonstrated in this video (do not use the factory reset or delete & reinstall the app)
Let us know how you get on.
Cheers
Gr4ndp4 | UK
Best AnswerNope, didn't help. It goes crazy when I sit and work by my computer, maybe something is disturbing the connection.
I don't have this problem at the office though, only at home. Strange
Best AnswerI am having this same issue, as I did in latter days of my charge 4. I upgraded to inspire as I thought it was due to old age of Charge.
mine is brand new and it had this problem immediately. It’s no use having a tracker if it doesn’t work properly. How can this bug be fixed? Yes, updated app and restarted device (which I shouldn’t have had to do as it was new.)
would appreciate help in fixing this
Best AnswerHi, @Janrob61 & @Zirqon can you please describe what your Inspire 3 is doing "Going Crazy"? If as mentioned in an earlier post you have an elevated HR check out How do I track heart rate with my Fitbit device? If you have been using your keyboard remember your Inspire 3 analyses arm movement as steps How accurate are Fitbit devices? explains some of the issues and How to make your fitness tracker count steps more accurately - The Verge offers a third-party view. The Kcal & AZM counts are directly linked to the HR data.
I hope this helps but please post here again if you have further questions.
Cheers
Gr4ndp4 | UK
