Inspire 3 notifications not working since firmware update
Everything else is working but my inspire 3 will not vibrate to give me notifications since the latest firmware update I have reset the Fitbit I have restarted my phone I've even done the test notification that works but none of my actual notifications work any ideas?
Moderator edit: clarified subject.
6 REPLIES 6
A warm welcome to the community forums @Lltcna12
Thank you for taking the time to share this information with me regarding the difficulty that you are experiencing with your Inspire 3 and for trying to fix it on your own.
Please make sure to follow the steps listed in this help article: Why didn't my Fitbit device alert me?
Try to restart the device as indicated here: Why didn't my Fitbit device alert me?
Following as I am having the same issue. I get the reminders to move etc but am not getting call, message or iPhone reminders since the update
I have noticed that there is now an icon on my fit bit that shows a phone icon with a line though it. I have now discovered that I can only get notifications if I have the Fitbit app open on my iPhone as well, when previously I didn’t.
I have can’t find anything obvious in settings to change this back. I don’t keep the Fitbit app open as a routine to conserve battery and data. If this is a permanent change, it is going to be annoying.
I also can’t seem to sync my Strava data or add a manual activity since the update
After latest update I have the same problem! My phone and Inspire 3 are not connecting. There's an icon of the phone striked through :mobile_phone_off: on the watch. No notifications are going through. It's very annoying! I regret doing the update.
since posting this, I’ve tried loads. Googled and the symbol suggests the watch is on DND, it wasn’t.
I switched on dnd and sleep mode then switched back off again. Notifications now seem to be working again.
Becky Prince
Sent from Outlook for iOS<>
Oh! I'm happy it worked for you. Unfortunately, with mine no success. I cannot sync with the phone so it's basically not working anymore.
Spoke too soon. It seemed to go back and showing no phone connected again 😞
Still can’t log manual activity or link to Strava.
-------Moderator edit - Personal information removed
