09-26-2022
04:38
13:15
YojanaFitbit
09-26-2022
04:38
13:15
YojanaFitbit
I am starting the topic again because it was not answered satisfactorily. I just purchased the inspire 3 as an upgrade to my old loyal fitbit. I used my fit bit to check my sleep score. I want to improve my sleep. I check my stages of sleep, etc. My new fit bit only tells me how many hours I slept and nothing else. This is not an upgrade. Please, does anyone know how to fix this? I should have more features on a newer device not LESS.
09-26-2022 14:10 - edited 09-26-2022 14:15
Hi there, @Mamivaz09. Welcome to the Community Forums.
I've move your post to a new thread to keep organized the forums and help others having similar inquires about this topic.
I understand your concerns about what happened last night with your new Inspire 3, but I'd like to check some details before taking a final decision. Thanks for all the details shared in your post.
As a first approach, I suggest restarting your Inspire 3 and try again tonight. Since it's a new device, it might have to calibrate your sleep.
On your Inspire 3 you should be able to see sleep time and sleep score and on the Fitbit app you will see all details and graphs about your sleep. When you're not getting your sleep stages you usually get your sleep pattern (asleep, restless and awake time).
Hope this helps.
09-26-2022 15:47
09-26-2022 15:47
Please remove me from your community. Thank you. I do not find what I need here.
Best Answer09-26-2022 23:05
09-26-2022 23:05
@Mamivaz09 Sorry you feel that way about your interaction with us.
Please note that only you can close your Fitbit Community account. See: How to: Close Your Community Account.
Thank you for sharing your feedback with us.
