Inspire 3 or versa 2 à better if both at similar price?
I have an inspire 2. It’s around 1.5 years old. The clock get dim and dim. I find it hard to read clock. Hardly able to read clock outdoor and indoor. Highly annoying.
I only use it for swimming to watch out on time and track my swimming activity.
so should I upgrade to inspire 3 (AMOLED screen) or versa 2 (bigger screen but OLED, same technology as inspire 2). Both similar price range. Which one will solve my issue of reading the clock and better suit for swimming only.
(Note I have mild long sighted but not serious. Bigger screen is good but i only want to read time on watch screen. My wrist is quite small)
2 REPLIES 2
Hi, @JG00 , I personally find the Inspire 3 screen very bright and clear and easy to read (it’s an enormous improvement over the Inspire 2) so if you like that size and form factor my advice would be to stick with the Inspire series.  You’ll find it familiar to navigate and easy to use, with very similar features and functions to the Inspire 2.  It will even fit some of the same bands (the soft ones and leather ones fit, the metal and silicone ones do not).
I hope this helps!
Thanks Julia. I really like inspire small light tracker feel. My concern is that if I get back to same issue with inspire 2 screen issue that I can’t read the time. Then it defeat the purpose.
Thanks for your reply and give me some comfort on that.
Thanks you.
