03-04-2023 05:25
03-04-2023 05:25
Hi. The black has a partly green colour display, the lilac has lilac & the yellow has yellow. If I get a different strap can you change the display colour?
Best Answer03-04-2023 06:12
03-04-2023 06:12
Hi, @Carlè welcome, I'm assuming your Inspire 3 display is operating correctly and your question is about the clock face settings. You do not mention which clock face you are using. I'm using "Highlight" and I can change the colour schemes>from your Fitbit app "Today" screen touch your icon in the top left corner>Inspire 3 tile>gallery>clocks>Highlight>slide up to see the colour options.
A similar option may be available on the other faces, I leave you to explore.
Cheers
Gr4ndp4 | UK
Best Answer03-04-2023 06:19
03-04-2023 06:19
