11-04-2022 04:34
11-04-2022 04:34
Hi, from a week or so my Inspire 3 does not automatically wake when I try to read the time. It looks like it doesn't detect my wrist movement. The water block is not set, and I couldn't figure out what other setting could affect this behavior.
11-06-2022 01:57
11-06-2022 01:57
Okay, I figured it out. My device language is set to Italian, so I couldn't figure out that the setting "Sveglia automatica" actually refers to the screen wake. "Sveglia" actually translates to "alarm clock" when used as a noun, so I thought it was used to configure the alarm behavior. It looks like it's been machine translated from English to Italian, please be more careful when translating device settings.
11-04-2022
12:21
09:00
11-04-2022
12:21
09:00
Hi there, @calm_squirrel. Welcome to the Community Forums. Thanks for trying to troubleshoot this before reaching out. I understand where your concern is coming from and thanks for confirming you've checked that 'Water lock' if off.
Please make sure the 'Sleep mode' is not turn on. See How do I navigate my Fitbit device?
When sleep mode is on:
If this settings is set correctly, please try restarting your Inspire 3 by following these steps: How do I restart my Fitbit device?
Hope that helps.
11-05-2022 03:46
11-05-2022 03:46
Hi, thanks for the answer. Sleep mode was not turned on (I also tried to turn it on and off). Restarting the device did not solve the issue either.
11-06-2022 01:57
11-06-2022 01:57
11-11-2022 15:24
11-11-2022 15:24
I had the same problem. Make sure auto wake is turned on.
01-19-2023 14:46
01-19-2023 14:46
Thank you very much you helped me, the translation in Italian is wrong. Now it’s working!
