09-13-2023
19:21
08:37
09-13-2023
19:21
08:37
Hello, and thank you in advance for all responses.
I just purchased a new Inspire 3. I've had a few versions of the Charge before so am familiar with how the Fitbit is supposed to work. I have paired it to my app and charge it fully. But when I tap the screen nothing happens. Moving my wrist does not do anything to get a live screen. I have to click the side buttons once or twice together to get the clock face to show. When I do get it, as soon as I touch the screen to swipe up or down to see the menus it goes to black and I cannot access anything. Appreciate all troubleshooting advice, many thanks.
Best Answer09-13-2023 19:42
09-13-2023 19:42
09-14-2023 16:19
09-14-2023 16:19
Hello JohnnyRow, thank you for your response. The issue is that tapping the screen to 'wake up' does not always work and turning my wrist never works. I can hit the buttons to get the clock face. But as soon as I touch the screen to swipe it goes dark and I cannot access anything...
Best Answer09-14-2023 16:25
09-14-2023 16:25
I wasn't attempting to address your whole issue. But you mentioned 'when you tap the screen nothing happens'. I was pointing out that you have to tap the screen twice (and firmly), not sure if the Charge models you had might have just required a single tap.
