After working flawlessly for 3 years, my Inspire 3 has stopped displaying my exercise and stats on the tracker face. Auto-start is on and it's recording the exercise because it shows up in the iOS app when I sync but it no longer displays on the tracker. Until a few days ago, I would have to manually stop the exercise by pressing pause, then finish, then done and the exercise stats would be displayed. I have restarted the Inspire 3 and the battery is charged. Any ideas?
Apparently DND affects the exercise display that should appear after an auto-start exercise is stopped. I turned off DND (which I had accidentally turned on) and today my exercise was showing when I finished. I had to hit pause, finish, and done like I've been doing for years.
Best Answer@lmacmil Please check the settings one the affected shortcut to see if the Auto-start feature is toggled off. From your description, you are still getting that activity tracked by SmartTrack.
Laurie | Maryland
I verified that auto-start is on. There is a white circle with a dash (-) inside it when I touch the tracker screen. I don't recall seeing that before. What is it?
Best Answer@lmacmil That sounds like one of the Status Indicators, specifically the one that says you are in Do Not Disturb. How do I navigate my Fitbit device?
I don’t know if being in DND affects the Auto-start feature. I don’t use it.
Laurie | Maryland
