01-14-2025
18:03
03:46
01-14-2025
18:03
03:46
I love my fitbit.
I've had it for 2 years but the heart rate monitor, including the flashing lights on the back, just stopped working and just show a blank _._
In addition the settingd button from the watch itself had disappeared!!!
Help!
Best Answer01-15-2025 03:54
01-15-2025 03:54
Hi there, @overstim-mama. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Inspire 3 stopped tracking your heart rate. I understand your concern, I will do my best to help you with this!
I'd recommend resetting the heart rate settings on your Inspire 3 by following the steps below:
Regarding the button, would you mind giving more details? What do you mean by "it has disappeared"?
01-15-2025 12:18
01-15-2025 12:18
Hi there
I cant manually do any of that as my fitbit settings app no longer exists on my Fitbit watch. I don't know how else to explain that. I will first need guidance on how to bring that back before i can complete the other steps.
Best Answer01-15-2025 13:48
01-15-2025 13:48
Tap the Devices icon in the upper left-hand corner of the Today screen on the App and then tap the Inspire 3 icon. Next, tap the Gallery icon and make sure that the Settings App is installed on your device.
Best Answer01-15-2025 17:39
01-15-2025 17:39
Best Answer01-15-2025 17:44 - edited 01-15-2025 20:42
Does the device restart when it is in a charger and the two side-buttons are pressed for at least 10 seconds? If so, that might help.
Best Answer01-16-2025 08:02
01-16-2025 08:02
Best Answer01-16-2025 08:13
01-16-2025 08:13
That's unfortunate, because there is no way to perform a Factory Reset on an Inspire 3 device without using the Settings App.
It would be worth a try using the App Gallery to change the clockface to something else and then resyncing the device to see if that restores the missing Settings App. Maybe try restarting the device after changing the clockface as well.
Best Answer01-16-2025 09:28 - edited 01-16-2025 10:00
It appears that you are not the only one reporting this issue.
https://community.fitbit.com/t5/Charge-6/Settings-app-is-not-on-my-Charge-6/m-p/5712491#M17162
Give this possible solution a try with your Inspire 3.
Best Answer01-16-2025 10:46
01-16-2025 10:46
So i followed these steps although i wasnt given a "replace device" option.
I still dont see the settings app. It has to be the watch itself that is having issues. Is it possible to get it looked at or replaced?
Best Answer01-16-2025 11:08 - edited 01-16-2025 11:09
The Inspire 3 only has a 1-year Factory warranty, so getting a replacement device won't be possible, but someone with a Charge 6 was having the same issue, so it is probably not a bad device (corrupt firmware or software issue is more likely).
Try contacting Customer Support to see if they can help resolve the issue. A 4.34 Fitbit App update was just released, so it is a bit suspicious that someone with an Inspire 3 and Charge 6 device would both be having exactly the same issue.
Best Answer01-16-2025 18:08
01-16-2025 18:08
