07-09-2025
12:02
18:32
ManuFitbit
07-09-2025
12:02
18:32
ManuFitbit
Hi, I have an Inspire 3. The time shown is 4 minutes behind … I have updated, synced and everything. But the time is still off. Anyone know what to do?
Thanks in advance!
Moderator edit: clarified subject.
Best Answer07-13-2025 21:57
07-13-2025 21:57
Hi, thank you for the response. I have not been travelling across time zones. I would therefore wonder it that was the problem, plus the fault was only about 4 minutes.
However, after a gazillion updates and syncs, the problem got resolved.
Best Answer07-09-2025 18:29
07-09-2025 18:29
It's good to see you around @mmroe.
Thank you for sharing with me the information regarding this difficulty with your Inspire 3. Thank you for trying to fix it on your own.
Time on your Fitbit device may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Fitbit device is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I change the time on my Fitbit device?
I recommend changing your time zone to a completely different one, sync your device, put the correct time and sync again.
07-13-2025 21:57
