04-25-2024
10:15
07:40
04-25-2024
10:15
07:40
The problem I’m running into is when I’m inside Target my steps are not being counted. It’s happened quite a few times. I called for help and they really didn’t know what to tell me other than reach out to the Fitbit community. Help please!
04-25-2024 10:28
04-25-2024 10:28
Are you pushing a cart?
Best Answer04-25-2024 12:21
04-25-2024 12:21
Yes I was. Is that the problem?
Best Answer04-25-2024 12:54
04-25-2024 12:54
The Fitbit tracks steps by arm movement. If your arms aren't moving it doesn't know you are walking.
Best Answer04-26-2024 07:42
04-26-2024 07:42
Hi there, @jenscarry. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the inconvenience with your Inspire 3. I understand where your concern is coming from. We‘re taking into consideration your comments and sentiments with regards to our products and services.
As @lmacmil has pointed out, please note that if you're doing something like mowing, pushing a stroller or shopping cart, your wrist-based device will count your steps but the total may be slightly lower than usual.
For more information, see How accurate are Fitbit devices? and How do I wear my Fitbit device?
Best Answer04-27-2024 09:33
04-27-2024 09:33
If people are primarily interested in counting steps as apposed to sleep tracking, would wearing the Inspire 3 device clipped to the body instead of wearing it on the wrist help to resolve the issue of not counting steps while pushing a cart?
Best Answer04-27-2024 13:34
04-27-2024 13:34
Would you consider 540 steps slightly lower? I know that I wouldn’t. The most recent trip to Target I checked my steps on the Fitbit when I entered the store and what’s my health app on my phone said and that’s how I was able to determine the Fitbit missed out on 540 steps.
As far as pushing a cart, there are plenty of other stores I go in and push a cart and have not run into his problem. Just trying to find a fix for this! I’m not a Walmart shopper so I will continue to shop at Target:(
Is the Fitbit 3 Inspire mostly to track sleep? I know that’s. Not what I wanted it for and if that’s the case maybe I need to look for a different tracker. Help please!!!
Best Answer04-27-2024 15:33 - edited 04-27-2024 15:35
Here is someone that wore a Fitbit fitness tracker on her ankle for a week and she found that it worked quite well to count steps and measure pulse rate, at the expense of losing the ability to track sleep.
https://www.womanandhome.com/health-wellbeing/fitbit-on-ankle/
Best Answer04-29-2024 04:50
04-29-2024 04:50
It has always tracked my steps pushing a cart of any type before. Now I will have to test this new software version.
