08-31-2025 07:38
08-31-2025 07:38
A few years ago I reached my goal weight and stopped using my watch. Life happened, I gained the weight back, the watch is now back on.
Every time I try to change my starting weight, it just says, "cannot change goal whilst offline" and I absolutely am not offline, because the app won't even start if I'm offline?
Any answers on how I can change the starting weight?
09-01-2025 07:11
09-01-2025 07:11
Hi, @Raindancedanni , welcome to the community. I've tried to replicate your problem without success. Check that your Inspire 3 is paired with the Fitbit app on your phone and that you have an internet connection to your phone via WiFi or cell signal. Try syncing your Fitbit app (it will not sync without an internet connection). First, check that your cellphone is still compatible with the Fitbit app, as the minimum OS version is occasionally updated. Fitbit Setup Requirements - Help explains potential issues. If you have updated the Fitbit app on your phone (you do not mention the make or model), the latest Fitbit app version may no longer work on an older phone.
Let us know how you get on by posting here again.
Cheers
Gr4ndp4 | UK
