Inspire 3 won't respond to touch
My Inspire 3 won’t respond when I try to swipe up and down or left to right. It also will not recognize tapping to change the watch face. I can use the "buttons" to turn on and off the face or tap to wake it up, but otherwise completely unresponsive. It also seems to not be holding a charge anymore.
I have tried:
• Syncing the device from the app.
• Restarting my device.
• Changing the clock face.
• Disconnecting and reconnecting to the app.
Nothing seems to work. I got my Inspire in 2023. Does it only have a 3 year shelf life?
3 REPLIES 3
Hi, @web4win, welcome. May I suggest you check if your Inspire 3 is charged? In the "Today" app on your phone, the icon in the top left will display the battery %. If you can't see a value there, it would indicate the battery is fully discharged. If this is the case, you should check the charging cable. Give the back of your Inspire 3 a rub with warm, soapy water to ensure the contacts are clean. Examine the two spring-loaded pins on the charge cable puck to check they are of equal height and freely moving. Examine the USB plug at the other end of the cable, the USB socket you are using, and, if you have a USB brick, check the pins that go into your power source. These last connections might have become worn if you connect & disconnect them frequently; they do not have a reputation for being well-made. If neccassary try another USB brick or try charging another device from the brick you are using. If you suspect the charging cable or brick is at fault, replacements are available on Amazon for a modest price.
If your Fitbit app indicates the Inspire 3 is holding a charge, consider a factory reset.
Alternative/Unresponsive Device Method:
If the screen is frozen, put the device on the charger, then press and hold the side buttons for 10-15 seconds until the Fitbit logo appears, repeating if necessary.
Important Note: A factory reset completely deletes all stored data and returns the device to its original factory settings, effectively erasing it as if it were brand new.
I hope this is helpful. Please post here again & let us know how you get on.
Cheers
Gr4ndp4 | UK
Hello  @web4win and @Gr4ndp4! It’s nice to see you around!
Thank you so much @Gr4ndp4 for your support.
@web4win I'm sorry to hear that your Inspire 3 touch screen is not working.
It seems you've tried all the available solutions for this type of problem on your own. So, my best advice from here is to contact technical support. They have the most appropriate resources to help you more thoroughly.
Have you recently added a screen protector?
