09-10-2025
20:48
09:22
09-10-2025
20:48
09:22
My Inspire 3 will not sync with my ipad, which it has been working with since I got it almost a year ago. I have uninstalled the app and reinstalled in, Logged in and out, turned off blue tooth and reconnected, turned off my ipad. Please help me.
Best Answer09-11-2025 04:00
09-11-2025 04:00
Hi, @janelle816, welcome to the community. You do not mention which iPad you are using or its OS the minimum OS is, from time to time, increased. Please let us know the SW version you are on.
Cheers
The Fitbit app works on most phones and tablets. To use your Fitbit device, download the app on a device with one of these systems:
- Apple iOS 16.4 or higher
- Android 11 or higher
Gr4ndp4 | UK
Best Answer09-11-2025 09:28
09-11-2025 09:28
Hi there, @janelle816. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Inspire 3 is not syncing with your iPad. I understand your concern, we're here to help you!
In addition to what @Gr4ndp4 has shared with you. I was wondering if you're using another mobile device besides your iPad to sync your Inspire 3? If this describes your situation, please note that you can use more than one device to sync your Inspire 3. However, is very important to turn off the Bluetooth on one device when you want to sync with the other. Why? Well, bear in mind that Fitbit devices can only talk to one device at a time. It can be trusted on many devices, phones, tablets, and so on, but because of the limitations of Bluetooth, it will only be able to talk to one at a time.
The data from the Inspire 3 is sent to the Fitbit cloud. After the data has been processed it will be put into your Fitbit account. Now your Fitbit account has access to and will display the data. Opening the app on a second/third device/phone/tablet will have access to the same data and a sync is not needed if a sync recently occurred through a different device.
If you continue having syncing issues, please see Why won't my Fitbit device sync?
Best Answer09-14-2025 11:41
09-14-2025 11:41
Thank you for replying! It is an iPad mini 5th generation with iOS of 18.6
Best Answer09-14-2025 11:43
09-14-2025 11:43
Thank you for replying! The only device I have ever synced it to is my iPad. Any ideas appreciated. It just stopped syncing one day!
Best Answer09-15-2025 02:09 - edited 09-15-2025 02:10
Gr4ndp4 | UK
