Inspire 3 won't track my sleep data anymore
I have been using the inspire 2 to track my sleep and it worked well, now I decided to upgrade to the inspire 3. I have worn it for two nights now after attaching it to my premium account, and when I check after an 8 hour night of sleep, it tells me NO DATA. Now considering this was the main reason for using a fitbit is to track my sleep, this thing is useless. I have restarted it, made sure it was set to wear on the wrist, my sleep schedule is still set up. I have never started sleep manually and the inspire 3 won't start it either. After reading the forums it looks like this is a big problem with many. Should I send this back or is there an actual fix?
15 REPLIES 15
I've been wearing my Inspire3 fir a year now, and I've been having this issue more and more frequently recently. I can manually log sleep via the app after the fact and it will then kind of tell me "Oh, you DID sleep! Here's the data." But I'm very annoyed that I need to do that at all. I've taken all the steps, even reset my unit a few times. It's now happening 2-3 times a week.
I had the same issue until today. The sleep would be recorded in the app, but only showed up 1 time in the morning on my watch and then disappeared.  I just did a factory reset today. (found it on youtube (https://www.youtube.com/watch?v=6YGkivH5G8s)  Doing this prompted me to do an update, which took close to 30 minutes, but now it finally has my sleep recorded on my watch and is not disappearing.
I can't even get that, it doesn't give me anything at all. So there is nothing to edit or input.
Thank you, I will try this.
Good luck--Let me know!
I had this issue in August where sleep was recorded only for a total of 3Days.
I turned off sleep mode schedule in the band, and ensured every night to turn on “Do Not Disturb”- this worked for me, I have been getting complete sleep data for the past full week.
I had no luck with this,  I've also noticed the health metrics don't work as well as heart rate and sleep. Yet everything seems to be turned on. This inspire 3 is brand new and nothing seems to work. My inspire 2 work great.
I've also come to realize the health metrics,  the heart rate and sleep don't work, have been wearing it 3 nights now and nothing other that steps work. Yet everything is turned on and restarted etc.
Is the heart rate “On” in the band settings ? (Not in the app)
Sorry.  I checked this morning on my watch first, and the sleep was not recorded. However, once I went on the app on my phone, it registered on my watch. I would call Fitbit and see what they say.  Unfortunately, they did not help me, but it is worth a try.
So sorry--I hope you get it resolved
I don't wear my Inspire 3 at night and yet, it recorded 5 straight hours of deep sleep last night with no indication that a bad dream woke me up at 1:30 am.  There are a lot of mistakes with the recent update.
Yes everything is turned on, I've sent it back and ordered another one.
Please post the rhe sleep test results after you get your replacement device.
My wife didn't get sleep stages and HRV/BR heart metrics on her first device, or the next two replacement devices either, including the last one that I gave her that worked just fine for me
There must be something about my wife's heart rate or HRV measurement that makes it difficult for the Google-Fitbit Sleep algorithm to determine sleep stages, so we are hoping that Google-Fitbit releases another device FW or app SW update that resolves this performance issue.
Great! Good luck with your new one. Glad they let you send it back.
