10-04-2025
09:18
19:40
ManuFitbit
10-04-2025
09:18
19:40
ManuFitbit
Hi - I'm not even a month old with my new Inspire 3 fitbit but it will only sense and log walks, not any other exercises. I had the Luxe before this and didnt have this problem. I have changed the activity times but it hasn't helped. I see so many other similar complains and have turned it on and off and find this to be a lazy and insulting of a response to so many complaints so if I dont get a resolution I will happily return this and find other alternatives that work.
Moderator edit: clarified subject.
Welcome to the community forums @julietmugo1, @sln.
Thank you for sharing with me the information about this difficulty with your Inspire 3.
Even if you already tried some of the following steps, try to perform them one more time as indicated:
Best AnswerPlease provide the next solution after the on and off suggestion because it doesn't fix. I have done that countless times and I hoped you would provide another solution to try since I already mentioned that that didnt fix the issue
