I purchased this item for the vibration on receiving calls. My work often calls at all hours of the night. The product only vibrates twice which won’t wake me. I know the battery argument however without a decent vibration duration the product is essentially isles to me. Anyone aware of a fix?
Hi @MrSerious ! Warm welcome to the Community !
I appreciate your message concerning the Inspire 3 vibrations. I understand your feelings about this situation, and I'll be glad to suggest you some steps.
Could you please check "Other settings"on your Inspire 3, select : vibrations, and then adjust your tracker's vibration strength, as explained in the following help article: How do I navigate my Fitbit device?
Visit our Discussions board where you can share your experiences, meet people and create new topics.Si ma réponse vous a plu, merci de me féliciter. Si votre question a trouvé une réponse, acceptez la solution.If you liked my answer, give me a Kudo. If your question was answered, accept the solution.FR-EN-SPA.
Yes, I did read some other posts that suggested same. I did so however not convinced that my coma like sleep pattern will be disturbed enough to wake me. I think a lengthy bothersome vibration is what I personally need.
Hi @MrSerious ! Welcome back to the forums.
Thank you for your answer and for the additional information provided. I appreciate your readings and efforts.
I understand your point and I think it's a great idea.
This type of suggestion is welcome in the forum Product Feedback where users can post their ideas about what they would like to find on their devices.
To learn more about how Fitbit decides what product feedback is developed, visit our FAQs.
If you post as recommended, you can always post here the link, so other users can see it and vote.
