10-08-2022
22:57
12:22
YojanaFitbit
10-08-2022
22:57
12:22
YojanaFitbit
Hi! I'm wondering if the inspire 3 can use inspire 2, or any other model bands?
Best Answer10-09-2022 04:12 - edited 10-09-2022 08:01
Hello @lemondamon and welcome to the Community. I'm sorry, but no. The Inspire 3 uses a quick release lever, not the pin based mechanism like the Inspire 2.
Laurie | Maryland
Laurie | Maryland
11-25-2022 08:04
11-25-2022 08:04
The inspire 2 uses similar quick release lever as inspire 3, but the size of the 2 models is not the same, so, they are not interchangable.
Best Answer04-18-2023 12:32
04-18-2023 12:32
A bit late to the party, but my old original Inspire 1 band does fit in the Inspire 3. I was a bit disappointed at first when I heard old bands won't fit, but I figured I would see for certain that it didn't fit, but lo and behold, it does fit. Even with the original pins. So it won't hurt to try some of your old bands or get Inspire 2 bands from Amazon to see if they will fit. It does take a little finagling to get the pins to set in the hole, FYI. Work over a white towel, so you don't lose the pins.
