02-11-2025
22:25
15:13
02-11-2025
22:25
15:13
Just curious if i have have it on while doing dishes as I don't wanna mess it up if not
Hi there, @RedPandaLord. Welcome to the Fitbit Community Forums. Thanks for sharing your inquiry with us. I understand your concern, we're here to help you! @Gr4ndp4 Thanks for your input!
Please note most Fitbit devices are water-resistant to 50 meters. They're designed to be swimproof and stand up to even the sweatiest of workouts. See our user manuals for specifics as to whether your device is swimproof or splashproof.
Water resistance may diminish over time and can be negatively impacted by any of the following:
If your device gets wet, it’s important to take it off and dry it well before putting it back on. If your device comes into contact with any liquid other than fresh water, you should clean it with fresh water and a soap-free cleanser (like Cetaphil) and dry it with a lint free-cloth.
Hi, @RedPandaLord welcome to the community, I wear my Inspire 3 in the swimming pool daily. It's not let me down.
Cheers
Gr4ndp4 | UK
