03-21-2025
12:26
15:31
03-21-2025
12:26
15:31
Is there any way to add watersports to the Inspire 3, like kayaking, surfing, paddleboarding? Seems to be limited to swimming
03-21-2025 15:35
03-21-2025 15:35
Hi there, @Bhangbhanduc. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I will be glad to help you!
All the exercise shortcuts that you will find in the Exercise section are specifically designed to track the most out of each type of activity. The algorithms have been fine tuned to get more accurate data for each different exercise so that's the reason why there is a category for each.
When a specific exercise is not available within the exercises we offer, we suggest to use "Workout" (which is a generic catch-all for other types of exercise). Once you finish the activity, you can rename the activity to desired exercise/activity. Please note that the amount of calories burned vary from the exercise you're performing and due to the heart rate tracked by your Inspire 3.
Note that the information to enter will change depending on the nature of the exercise. To give you an example, if you change from "Workout" to "Run", it won't remove the calories but will add distance as the main stat to be displayed, this happen depending of the activity you are categorizing. However, your the data already tracked will be still counted for your daily totals.
For more information about how to do so, see How do I add, edit, or delete Fitbit data and activities?
03-21-2025 15:35
03-21-2025 15:35
03-22-2025 04:05
03-22-2025 04:05
@Bhangbhanduc I disagree with the advice given by @MarreFitbit. Please use the Outdoor Workout shortcut for these activities. It was designed for activities like this. She also gave you incorrect information about renaming an activity. The Fitbit app doesn't let us rename any activity.
Laurie | Maryland
03-22-2025 08:05
03-22-2025 08:05
Thanks, but there isn't an Outdoor Workout option for the Inspire 3, only Workout.
03-22-2025 08:06
03-22-2025 08:06
Thanks, I will try this option.
