11-29-2022 20:09
11-29-2022 20:09
My solution was to push it down my wrist but I have postural orthostatic tachycardia and the main reason I bought a Fitbit is to test my heart rate.... Will it be accurate if I push it down like this? Than
11-30-2022 08:16
11-30-2022 08:16
Hello @flowerpixel and welcome to the Community. I honestly believe that your wrist is too small for a Fitbit with a classic band. Your wrist looks exceptionally small. I’m not sure that the mesh band will help. I’m also not sure that a third party band will help, either.
Laurie | Maryland, USA
11-29-2022 20:10
11-29-2022 20:10
Another pic..
11-30-2022 08:16
11-30-2022 08:16
11-30-2022 18:13
11-30-2022 18:13
Thanks....Do you know if you have to wear a Fitbit literally right at your wrist? Does this look any better? It's on the tightest setting..
11-30-2022 19:16
11-30-2022 19:16
The recommended daily wear position is one finger width away from the prominent bone on your wrist. Your new picture is the recommended position during exercise — it helps with heart rate when your wrist might be bending a lot. I think there is a considerable chance that it will keep sliding down your wrist and you won’t get a heart rate trace at all.
11-30-2022 21:18 - edited 11-30-2022 21:18
Thank you! I looked into the child watches but they didn't get good reviews. I might try poking another hole in the band (if I decide to keep it)...I'm also looking at pulse oximeters
