Hi, @SallySwims welcome to the community, you can adjust the pool length on your Inspire 3.
From the clock face screen swipe sideways to exercise>swipe up to & touch swim, under the start arrow see the little chevron? swipe up 3 times to get pool length>touch pool length (25) & you'll see a sliding scale, swipe up to 50 & touch it to register>swipe right 3 times to return to the clock face - sync your Fitbit app on your phone.
I hope this helps.
Cheers
Gr4ndp4 | UK
Best AnswerHi, @SallySwims, the home screen on your Inspire 3 that displays your chosen clock face. Mine looks like this -
I hope this helps.
Cheers
Gr4ndp4 | UK
Best AnswerOh you meant on the watch, not in the app, my bad! After some fiddling I got it- thank you! Double tap to save new meter length 👍
Best AnswerHi, @SallySwims I'm pleased you have sorted this out, If you think it merits your support, it is open to you to mark my answer as "Choose as the Best Answer"
Cheers
Gr4ndp4 | UK
