01-19-2024 07:33
01-19-2024 07:33
Yesterday I had a stellar workout day and put in over 15,000 steps, when I checked my progress for today I looked at my dashboard and all of my other days were showing but not yesterday's, it shows as if I did nothing. I also saw that it stopped tracking all my nights of sleep so I start that manually each night when go to bed. Is there something I can to do on my end to fix these issues?
Best Answer02-05-2024 06:35
02-05-2024 06:35
Hi, @TurkeyGirl welcome to the community, it sounds as if your Fitbit app has not synced. You may find this article of interest - Why won't my Fitbit device sync? - Fitbit Help Center
Faced with your issue my first move is to manually sync the Fitbit app on my Phone. In the Today screen of the Fitbit app slide your finger down the screen & release, see the green progress bar move from left to right at the top of the screen. I find it necessary to do this twice sometimes as some data needs to be downloaded to the Fitbit server algorithm and then returned to your app. Under normal circumstances the Fitbit app will sync each time you open it - you do need an internet connection.
I hope this helps.
Cheers
Gr4ndp4 | UK
