08-11-2025
07:21
08:01
08-11-2025
07:21
08:01
I would like to send my Inspire 3 back to where it came from. It is the most frustrating and useless piece of technology I have ever had the misfortune to own.
Hi there, @Zimboy. Welcome to the Fitbit Community Forums. Thanks for taking the time to share your experience with your Inspire 3. We‘re taking your comments and sentiments in regards to our products and services into consideration.
To better assist you, may I know what are the issues or inconveniences you're experiencing? Are there any troubleshooting steps you've tried so far?
Please note that our products are indeed designed and made to last (this goes for each product component) however, there is not an infallible way to ensure that no issues will be present in the long run. Because of this, our Warranty Policy is set into providing as much coverage as we can. For more information about our warranty, see fitbit.com/legal/returns-and-warranty
Looking forward to hearing from you.
Best AnswerHi, would not hold charge past 4 days, used to go blank and then have to be rebooted at least once per month, failed to sync times zones despite changing settings several times and finally it just completely crashed...
Best Answer@Zimboy If you bought it from the Google Store, you start your return in your search history in the Google Store. Contact the seller if you bought it from a different retailer.
Laurie | Maryland
