09-11-2024 11:40
09-11-2024 11:40
My phonecposts more steps than my watch
09-11-2024 11:55
09-11-2024 11:55
Same issue here.
Best Answer09-11-2024 12:02
09-11-2024 12:02
Welcome to the forums @TM2024 @Davdanhog.
Thank you for providing the details regarding your Inspire 3.
Please confirm if you are using Mobile track. It is a service that allows you to count steps using your phone even if you forget to wear your Fitbit. You can "unpair" Mobile Track from your account. On your Fitbit app go to the upper left corner, on the phone and device icon. Click on your phone icon and on the 3 dots and choose "unpair".
Best Answer09-11-2024 14:31
09-11-2024 14:31
Best Answer09-11-2024 19:25
09-11-2024 19:25
If the phone icon is under 'Add Connections', instead of under 'Devices', then you are not using Mobiletrack.
You would have to manually add your phone as a Device to enable Mobiletrack.
Best Answer09-11-2024 19:38
09-11-2024 19:38
Best Answer09-11-2024 20:50
09-11-2024 20:50
You will need to remove your phone from the Devices list to disable Mobiletracking.
Best Answer09-13-2024 20:40
09-13-2024 20:40
