New Inspire 3 won't track my sleep data
ANSWERED
I just got an Inspire 3 yesterday and I wore it to bed but it didn't record any sleep data. Do I have to manually click "begin sleep" in the app for it to record sleep?
1 BEST ANSWER
Accepted Solutions
Hi there, @jamaykans. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your Inspire 3.
Since you just bought the Inspire 3, give the RHR a few days to settle down. It does some calculations, looking at heart rate throughout the day and while you are sleeping, so it might just not have enough data to give a reasonable value yet.
In addition to that, I recommend considering the following in order to get sleep stages:
  • If you slept in a position that prevented your device from getting a consistent heart-rate reading or wore it too loosely. For best results, wear your device higher on your wrist (about 2-3 finger widths above your wrist bone). The band should feel secure but not too tight.
  • If you used the Begin Sleep Now option in the Fitbit app (instead of simply wearing your device to bed). For more information on automatic sleep tracking, see How do I track my sleep with my Fitbit device?
  • If you slept for less than 3 hours.
  • If your device’s battery is critically low.
For more information, see What should I know about Fitbit sleep stages?
1 REPLY 1
