On which arm should device be placed? Inspire 3
On which arm should device be worn?  Inspire 3
3 REPLIES 3
@tmsascgmail   On the wrist that you usually wear your watch.
Laurie | Maryland
It's really your choice.   During setup you say which arm you are going to wear the device, dominate or non-dominate.   It does normally go on the arm you would wear a watch, because that is what most people are comfortable with.    It's just a habit for us to look at one wrist over the other to look for the time.
Thanks!!!!
