Recommendations for replacing my Inspire 3
I lost my Inspire 3. I need a replacement. Which model should I get? Either by FitBit or a competitor.
I only used my Inspire 3 to track sleep and runs (distance, speed, calories burned).
I'm inclined to simply get another Inspire 3. But is there something better?
In particular, I'm curious if I'd benefit from a built-in GPS. It always seemed to me that using my phone's GPS was perfectly adequate. But perhaps I'm wrong.
1 REPLY 1
Hi @vinismatr, welcome to the Fitbit Community! It's great to have you here!
I'm sorry to hear you have lost your Inspire 3. On the other hand, i appreciate that you remain considering sticking to our brand.
The concept of "better"here is defined by a device's ability to perfectly meet your expectations. By your wording, I believe a device with a built-in GPS is not a need. However, some users prefer not to carry their mobile while tracking their activities.
Finally, you can take a look at our comparing tool to get some help in regards to what to choose according to your needs.
