03-08-2024
09:18
09:58
03-08-2024
09:18
09:58
I’m not getting the buzz notification at 10 to the house when I haven’t hit 250 steps
Best Answer03-09-2024 03:47
03-09-2024 03:47
Hi, @Luiset , are Reminders to Move set up in the app? From the opening screen of the app click on small icon top left (smartphone and watch). On the next screen click on your Inspire and scroll to find Reminders to Move. Make sure it is set to ON. You can also set up the hours when you get the reminders and 10 minutes to the hour.
If RTM is on but you still aren’t getting reminders, please toggle the button to OFF and then sync your Fitbit. Next turn the reminders on again and sync once more.
I would also recommend giving your Fitbit a restart.
Hopefully you will get your RTM after following these steps. Welcome to the Community Forums!
03-09-2024 17:19
03-09-2024 17:19
