Report Weight - Adobe Issues
Good Morning, in the portal could be useful to have 360° over view about the Kcal used over time, now is working only the Kcal by day, if i try to use the tool for the over 30days, required to me to install adobe that is deprecated since 2020.
do you have a work-around for this ?
Thanks
1 REPLY 1
Hi, @Gnux , it sounds like you are using the web based Dashboard to check on this.  I have reported to Fitbit that some features of the Dashboard are still requiring users to install Adobe.  However the answer I got was that fixing Dashboard bugs was a “low priority” as most users now access their information via the app.
You can see see a monthly overview of your calories in the Food tile on the app.  Click on the food tile and a graph of calories in vs out is available by the week or month.  If you have logged your food you will also have a graph of macronutrients.
I hope this helps.  Welcome to the forums!
