Screen wake is not working on my Inspire 3
ANSWERED
Should my Inspire 3 show the time when I flick my wrist or must I tap it? Flicking does not seem to work.
1 BEST ANSWER
Accepted Solutions
Hello there, @ronrabbu. Thanks for stopping by in the Fitbit Community Forums.
Regarding your inquiry, it should work both ways depending which one you've enabled. If you haven't done so yet, please go to your quick settings and check if the screen wake has been accidentally been turned off. To do so,  swipe down from the clock screen. Tap a setting to adjust it. to access the quick settings. Here you can change whether the screen turns on when you turn your wrist. For more information, see How do I navigate my Fitbit device?
1 REPLY 1
