03-02-2025
02:55
05:03
03-02-2025
02:55
05:03
My Auto Wake feature seems to have stopped working. When I go to reset it, then hit the 'save' button, it shuts it right off again. If I don't hit the 'save' button, that it, of course, doesn't save it either. I've even tried a whole new Restart, hoping it would help, but no such luck. Any suggestions? TIA!
Best Answer03-02-2025 05:07
03-02-2025 05:07
Hi there, @PeacefulMary. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that the screen wake on your Inspire 3 is not working properly. I understand your concern, I will do my best to help you with this!
It could also be possible that your Inspire 3 is in sleep mode. When the sleep mode setting is on:
To turn off Sleep Mode, swipe down from the clock screen. Tap a setting to adjust it. . For more information, see How do I navigate my Fitbit device?
If the above doesn't describe your issue, please go to your quick settings and check that screen wake hasn't accidentally been turned off. swipe down from the clock screen again and tap the setting to adjust it. Change whether the screen turns on when you turn your wrist.
03-02-2025 05:07
03-02-2025 05:07
03-02-2025 05:38
03-02-2025 05:38
Thank you! I think that solved the problem. 🙂 I appreciate your help!
03-04-2025 07:29
03-04-2025 07:29
@PeacefulMary You're very welcome! I'm glad to hear that your issue is now solved.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
