Skin friendly, inspire three band
So has anyone found a band that is not silicone that fits the inspire three? I have yet to find anything. I have a fake leather band that was on my inspire that fits my inspire three. So if the bed fit the original inspire, it will also fit inspired three. I haven’t found another fake leather or nylon band that fits the inspire three. There was a nylon bad that said it fit inspired to inspire, and I forget the other one, but it cannot fit the original inspire, and inspire to the way you connect a band to the inspire2 is not the same as the original or the inspire three  so if the band is not silicone, and it says it fits the original on fire, or the inspiratory, it will work  I don’t even look up fans for the inspired the original one and all Amazon has are some bands that are nylon, but they inspire two and inspire, which is impossible and then I read the reviews but they don’t fit inspire three. So I need a band that is not silicone because I’m allergic and my fake leather band from my original inspire is starting to get gross so I need to find something else and everything I found on Amazon is silicone or it’s only for the inspire two.
2 REPLIES 2
There are now quite a few inexpensive woven stretch bands on amazon that fit Inspire 3. You need to search for inspire 3 bands. Most also fit all models of inspire because the attaching ends are not curved such that they will only work with a given model.
Scott | Baltimore MD
 I ordered from Amazon a leather band.  It has not yet arrived. When it does I will provide an update.  The info on the band said it fit both the Inspire 2 and Inspire 3. I believe the two trackers have different fixtures for the band, so I am a bit sceptical about the product, but we'll see when it arrives. Again I will update then.  UPDATE:  package ironically just arrived !  The band most certainly does fit the Inspire 3!  A bit finicky attaching it, but eventually it did and seems secure.  Is the product truly leather? Juries out on that, but it definitely isn’t rubber or silicone! The packaging says Nigaee - Fashion Watch Bands. There was brown or black to choose from. I got black as seen in the picture.
