Stat option for Inspire 3 that shows the numbers in a row .
Is there such a thing as the stat heavy option for Inspire 3 that show the numbers in a row and not all over the place? Had I seen the options before have I would have stuck with my Inspire 2. Who thought this was a good idea for almost all of the faces??
Moderator edit: clarified subject. .
2 REPLIES 2
@MeMe-D -- I don't really remember what the clock face options for the Inspire 2 were. There are quite a few options available for the 3. There is not a lot of screen real estate, and I like big numbers for the time, so they work for me. In case you didn't know, in many cases if you tap the screen then typical metrics, active minutes, steps, distance, HR, rotate through the non-time field.
Scott | Baltimore MD
Hi @MeMe-D, I haven't changed my watch face for a while now, but I know there are glam, aura, and simple that you can use, and they are just simple options. There is unfortunately not a heavy stat option though.
