03-23-2023
13:46
15:27
JuanFitbit
03-23-2023
13:46
15:27
JuanFitbit
Like I just hate the display on the inspire three I can barely tell because it’s so tiny. What’s the battery percentage is. I’ve literally had to go to my iPhone, and use the magnifying and zoom in to see the percentage of the battery. It was that bad. It’s really hard to see even someone in their 30s who doesn’t have that bad of eyesight can’t even read it like what are you expect? Everyone has 2020 vision like it’s small and not very clear I believe somewhere in the Fitbit app it should tell you the battery percentage, but sometimes I think that’s not very accurate.
Best Answer03-24-2023 07:17
03-24-2023 07:17
Hi, @Kittycat714, welcome, I must admit I tend to agree with you about the size of the battery "SOC" display on the Inspire 3. While it's unlikely a change can easily be made you might like to put forward your suggestion at Fitbit Community. It's worth checking in the search bar to see if there is a similar idea you could vote for to make your voice heard. A simpler way to check the SOC on your phone will be to open the Fitbit app & slide your finger down the home (Today) screen to see the value next to the battery icon in the top right.
I hope this helps.
Cheers
Gr4ndp4 | UK
