09-14-2024
21:14
04:50
09-14-2024
21:14
04:50
How do I set the time, It's 3 hrs behind.
Best Answer09-15-2024 04:56
09-15-2024 04:56
Hi there, @BEAU72. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I'm sorry to hear that your Inspire 3 is showing the wrong time. I understand your concern, I will do my best to help you with this!
As per the description of your post, it sounds like your Inspire 3 is not syncing or hasn't synced. To make sure your Fitbit device has recently synced, go to your Fitbit app and tap the Today tab, and then tap Devices. Keep in mind that your Fitbit device uses the time of the device you're syncing with.
If by any chance you're facing syncing difficulties, please see Why won't my Fitbit device sync?
If the issue is still not solved, but you can confirm that your Inspire 3 is syncing, please try changing your time zone to a completely different one, sync your device, put the correct time and sync again.
Lasty, please make sure that your Inspire 3 is up-to-date. For more information, see How do I update my Fitbit device?
Best Answer09-16-2024 22:34
09-16-2024 22:34
