04-27-2025
03:04
10:06
MarioSFitbit
04-27-2025
03:04
10:06
MarioSFitbit
I feel that this is a bit of a silly one, but it irritates me that turning my wrist hardly ever turns on my Fitbit display - I have to do the double tap. Any tips on how to fix this? Is my wristband too tight? Am I being too energetic with the movement? I just had a run of a few days when it worked perfectly, but now it’s stopped again 😡
Moderator edit - updated subject for clarity
Best AnswerHi, @Omiattheairport, welcome. My Inspire 3 continues to work as usual, including the auto-wake feature. May I suggest checking the "Settings" on your Inspire 3>swipe down x 1 from the clock screen to "Autowake" and ensure the icon indicates "on" (you can change the setting by tapping the tile), it's possible you may have inadvertently changed it to "off". If you still have this problem try restarting your "Inspire 3"> swipe down from the clock screen and touch "Settings">swipe up to "Display">swipe up to autowake & check it's "on">swipe up to the very bottom of "Settings" and restart your Inspire 3
I hope this helps, please post here again & let us know how you get on.
Cheers
Gr4ndp4 | UK
Best AnswerHi, @Omiattheairport , well done, I'm pleased you sorted it out.
Cheers
Gr4ndp4 | UK
