12-23-2023 00:53
12-23-2023 00:53
Upgraded to Inspire 3 from Inspire 2 as screen too small & dim.
Questions
1. Which faces have largest figures & show steps? I can only find a few compared with Insp.2
2. How do you set pool length?
3. How do you set alarms? Insp. 2 had 0700 and 0730 but Insp. 3 seems stuck on only 0820! Maybe it thinks l need more sleep 🙂
12-23-2023 07:32
12-23-2023 07:32
Hi @pk316 your post was moved from the iOS forum to the Inspire 3 forum so you can get more relevant responses.
Alarms - learn how to set them by following the directions written on this article - click to read.
Pool length - read this
Faces - you'll need to try a few and see which one works best for you.
12-23-2023 08:14
12-23-2023 08:14
12-23-2023 09:13
12-23-2023 09:13
I've asked a Fitbit Moderator to stop by to help make things more clear for you.
12-27-2023 11:21
12-27-2023 11:21
@Odyssey13 Thank you for your help.
@pk316 A warm welcome to the Community! Thank you for reaching out.
I'll try to explain a bit better the info on the help articles.
On you mobile device, open the Fitbit app .
Tap on the devices icon (upper left corner)
Select the Inspire 3> Gallery>Clocks. You'll see here all the clock faces available for the Inspire 3. Select the one that better fits your needs and install.
Alarms
You mentioned that the alarms are stuck on 8:20.
On the alarms app you'll see the latest alarm displayed.
Scroll up and you'll see the others alars set, and the option to add one more. Keep in mind that you can only have a max of 8 alarms set.
If you see the options grayed out, try deleting one .
Pool length:
On the Inspire 3, tap on the exercise app.
Select Swim.
Swip up > Pool Length.
you'll see the options to set up the pool length.
