Is it possible to use my Fitbit device without a phone?
I’m sure this has been asked but searching didn’t get to quite what I needed. I’d like to use my Fitbit Inspire 3 without my phone. No calls, calendar notifications, nothing. I have tried a few things and haven’t figured it out. Appreciate any tips! I don’t care about syncing or saving data. Just want to be able to tell time and track activity in the moment.
1 REPLY 1
Hi @kriyapedo   I’m sorry, but you need a phone or tablet to use your Fitbit.  You must sync periodically to keep the correct time on your Fitbit.  Otherwise it will drift.  You need an internet to correct the time if you travel across time zones or if you live in an area where you change from standard time to daylight savings time and back.
Laurie | Maryland
