I am very new to Fitbits etc. I do Aqua aerobics a lot and use it for that. There does not seem to be a water workout option(?), so I have been starting a regular Workout option and it seems to work ok. But then I can not put the water lock on once in that mode. If I put the water lock on first I can not start the activity mode. I don’t want to set it for swimming instead as that does not reflect the type of exercise I am doing. The water washing over the screen occasionally stops the exercise mode. Help please?
Hello @Ros5 and welcome to the Community. You point out a significant limitation with the water lock feature. Sadly, there is no current good option. Please vote for and leave a comment on this Feature suggestion. I know it's for the Charge 5, but the Inspire 3 has the same issues. I have the same issue with the Sense 2 -- and it has a longer list of water sport shortcuts.
Laurie | Maryland
Best AnswerHello @Ros5 and welcome to the Community. You point out a significant limitation with the water lock feature. Sadly, there is no current good option. Please vote for and leave a comment on this Feature suggestion. I know it's for the Charge 5, but the Inspire 3 has the same issues. I have the same issue with the Sense 2 -- and it has a longer list of water sport shortcuts.
Laurie | Maryland
